-   -   UDF for slip and moving wall (http://www.cfd-online.com/Forums/fluent/36724-udf-slip-moving-wall.html)
lichun Dong May 20, 2005 11:25
Dear all:
I am trying to put a slip and moving boundary condition at the wall. so I write a UDF as the followed. But the FLUENT said there is a fatal problem "Segmentation violation". I select moving wall and non-slip at Fluent, maybe that is the reason? But if I select slip wall, I can not specify the wall velocity. Anybody has some experience to put a slip moving wall boundary? please give some suggestion.
Thanks a lot
#include "udf.h" DEFINE_PROFILE(wall_velocity,t,i) { face_t f; cell_t c; real cellnumber = 0; /*the number of the cells on the boundary*/ real A = 0.002; /*the amplitude of the oscillation*/ real omega = 100; /*the frequency of the oscillation*/ real dudy; /*the y derivative of the horizontal velocity*/ real sumdudy = 0; /*the sum of the velocity derivative*/ real avgdudy; /*the average of the velocity derivative*/ real beta = 0.2; /*the slippy coefficient*/ Thread *tc;
tc = THREAD_T0(t);
if (NULL != C_DUDY(c,tc)) {
begin_c_loop(c,tc)
cellnumber = cellnumber + 1;
dudy = C_DUDY(c,tc);
sumdudy = sumdudy + dudy;
end_c_loop(c,tc)
avgdudy = sumdudy/cellnumber;
begin_f_loop(f,t)
real tempt = RP_Get_Real("flow-time");
F_PROFILE(f,t,i) = omega*A*cos(omega*tempt) - beta*avgdudy;
end_f_loop(f,t)
} else {
begin_f_loop(f,t)
end_f_loop(f,t) } }
lichun Dong May 21, 2005 21:55
How to access variables in Fluent
Dear all:
This seems a hard question. I checked that once I try to access the variables, the "Segmentation violation" appears. So what is the trick to access the varibles in Fluent?
I attached my UDF again. #include "udf.h"
DEFINE_PROFILE(wall_velocity, t, i)
face_t f;
cell_t c;
real A; /*the amplitude of the oscillation*/
real omega; /*the frequency of the oscillation*/
real dudy; /*the y derivative of the horizontal velocity */
real sumdudy = 0; /*the sum of the velocity derivative */
real avgdudy; /*the average of the velocity derivative */
real beta; /*the slippry coeeficient*/
if (NULL != C_DUDY(c,t))
begin_c_loop(c, t)
cellnumber++;
dudy = C_DUDY(c,t);
sumdudy =+ dudy;
end_f_loop(f,t);
begin_f_loop(f, t)
real t = RP_Get_Real("flow-time");
F_PROFILE(f,t,i) = omega*A*cos(omega*t) - beta*avgdudy;
end_f_loop(f,t);
else
begin_f_loop(f, t)
F_PROFILE(f,t,i) = omega*A*cos(omega*t);
end_f_loop(f,t);
ramesh May 30, 2005 14:24
Re: UDF for slip and moving wall
Hi, DEFINE_PROFILE takes input the boundary face not the cell. So when u are running a loop on the faces u cant access the particular cell directly. Because the thread for face is different from thread for cells. If u want to access the cell of the partciular boundary face use F_C0(f,tf). I hope this should solve the problem
elaf_2003 March 26, 2014 05:37
moving wall slip
Hi all
I was wondering if any body can help me?
I am using flow around cylinder, the shear stresses at the wall need to be specified to constant value. In this option, there are 3 components for the shear stresses, i.e. x direction components and so on.
Does anyone know for example how can set these values for cylinder surface
Regard.
