Gambit - Block meshing problem
Old   May 22, 2005, 01:21
Default Gambit - Block meshing problem
tom
Hello
I am trying to mesh a complex geometry with various interior obstacles. My initial idea was to create the outer volume geometry and then create bricks or cylinders around the interior elements, so I would have more or easier control over how to mesh those interior elements (like valves, nozzles etc) and also did not have to do everything at once, but test things step by step.
To test my idea I am meshing the following simple mesh. A bigger brick as the outer volume, and two smaller bricks inside, one at the bottom, one at the top. I created the outer brick, and the two inner bricks, now my problem is, how do I connect the faces where the inner bricks overlap with the outer brick.
I have tried spit volume (small brick split with outer brick). However, if I try the same with the second inner brick (split second small brick with the remaining outer brick) gambit places walls where the first inner brick intersects the outer brick.
So, I guess that is my question. Maybe someone can explain the steps that I have to follow for the above example.
Thanks, Tom
Old   May 23, 2005, 11:36
Default Re: Gambit - Block meshing problem
Alec Eiffel
Hi Tom
If i understand the problem correctly it is that gambit is creating two faces between volumes, whcih means the mesh is not connected.
There is a simple solution to this problem. after splitting all volumes and before meshing any volumes go to GEOMETRY -> FACE. In that section you will find a CONNECT/DISCONNECT FACES button. select this and in the faces selection box select "all".
This will delete any disconnected faces.
Old   May 26, 2005, 11:02
Tom
Thanks Alec.
I will try your suggestion. I have not really paid too much attention to the defaults panel.
I was able to solve the problem I described by always splitting the larger volume with a smaller one. However, I do believe that the resulting "geometry" was not clean, i.e. like you mentioned must have contained disconnected faces.
Tom
GAMBIT meshing problem for boundary layer Falah FLUENT 2 November 30, 2020 14:16
[ICEM] Multiple fluide zone in ICEM Hexa Block problem ddqp ANSYS Meshing & Geometry 4 October 9, 2013 10:57
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
Problem meshing with Gambit Adrian FLUENT 8 October 7, 2008 08:39
Gambit Meshing Problem Drew FLUENT 3 April 1, 2005 10:50
