Home > Forums > FLUENT
Convergence problem
Old   May 24, 2005, 07:05
Default Convergence problem
Saad
Can anyone please tell me the techniques of getting a converged solution for unsteady, compressible turbulent flow with species transport.
Sincerely,
Saad
Old   May 24, 2005, 11:13
Default Re: Convergence problem
Mehdi Ghoddosy
You can use low under relaxation factors for the parameters that more divergence is observed. On option is to use low relaxation factor for first time steps/interations and then use high relaxation factor. Using low relaxation factor will slow your solution.
Regards
Old   May 27, 2005, 07:49
soundar
In the solution control panel , go to surface -- > residual . there u could find convergence resolution criteria of 0.001 will be ther u just change it to o.1 and run. Also u could reduce the moment value from default of 0.7 to o.2 as such in the solve,control options. thus u could bring the convergence
Thread Tools
Trackbacks are On
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 06:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 04:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 01:24
