Controlled Meshing with GAMBIT
Old   June 12, 2005, 01:25
Default Controlled Meshing with GAMBIT
Masood
hi i have some complicated geometry or lets say any complicated geometry. How can i generate a mesh of my choice i mean like coarsen and fine in my desired places. Any suggestions plz. GAMBIT just give TGRID when a complicated volume is selected fr meshing.
Thanks in advance
Old   June 12, 2005, 19:21
Default Re: Controlled Meshing with GAMBIT
khairy
dear Masood it is very easy to controlled the grid spacing in Gambit: from Mesh --> edge select an edge by shift+click then from type select suucessive ratio say 1.2 in the part of spacing select interval count u will see the effect of that at once. for more detail contact me at omrkhairy75@yahoo.com or refer to Gambit help to read about Meshing
have a good luck Khairy _Egypt
Old   June 13, 2005, 09:26
Jason
That works well for 2D and 3D structured meshes, or 2D unstructured meshes. For 3D unstructured meshes, I highly recommend using sizing functions.
Hope this helps, and good luck, Jason
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 06:22
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 02:09
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 21, 2006 00:31
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 06:04
