Home > Forums > FLUENT
Boundary condition-reverse flow
Old   May 27, 2005, 18:00
Default Boundary condition-reverse flow
jyang
Hello everyone,
I am simulating infilling of sand slurry into a water pond. The pond is filled with water initially then sand slurry (two phases) was sprayed onto the water surface. I really can not configure out how to set up this inlet boundary.
I simplify the inlet zone as a round surface with the same area as the pipe with which the sand slurry was sprayed onto the water surface. Then another problem come s up. Since the elevation of the pond surface moves up as more and more sand slurry was sprayed, how can I set up the outlet boundary. Should I set the remaining area of the top pond surface as pressure outlet. But if I do that, the reverse flow will occur at the outlet, especially close the inlet boundary. So, could anybody please give me some advice?
Thanks,
Gavin Yang
Thread Tools
Trackbacks are On
Wind turbine simulation Saturn CFX 45 February 8, 2016 05:42
Need Help on boundary condition in Multi-Phase flow creddy_trddc CFX 0 December 9, 2010 08:53
mass flow in is not equal to mass flow out saii CFX 2 September 18, 2009 08:07
outflow boundary condition for multiphase flow deepak FLUENT 1 June 21, 2007 08:23
Boundary condition for not fully-developed flow John FLUENT 0 July 15, 2005 07:07
