-   -   vof help (http://www.cfd-online.com/Forums/fluent/36790-vof-help.html)
satyanarayana May 30, 2005 01:26
vof help
can i use a vof model for simulating turbulent flow.while im using im getting an error.can anyone help me in this regard.
Manoj May 30, 2005 10:10
Re: vof help
Whats the error ?
ramesh May 30, 2005 14:01
Re: vof help
there is no turbulence modelling available in vof. u can't apply is ur problem is twophase flow?????
satyanarayana May 30, 2005 16:42
Re: vof help
i have to simulate the flow for a body floating in water
Manoj May 30, 2005 17:02
Re: vof help
Hi
Turbulence modelling is available in vof, but its not suitable for multiphase problems. e.g I had simulated flow around a ship using VOF, k-epsilon model and I found that resistance was over predicted. It was more then twice the experimental value.
Laminar model agreed better with the experimental results.
Manoj
Manoj May 30, 2005 17:10
Re: vof help
Hi Satyanarayana
Try VOF (geometrical reconstruction), laminar, unsteady ( for both steady and unsteady state problems)..
What error are you getting? You might be getting it because of wrong inputs.
Regards, Manoj
satyanarayan June 7, 2005 15:26
Re: vof help
im getting the turbulence intensity is limited to 1*10^5 in sme cells for some iterations and then it is showing floating point error and then stopping,can u help me in this regard
