Home > Forums > FLUENT
Under-relaxation Factors
Old   June 1, 2005, 13:28
Default Under-relaxation Factors
rachid
Hi everybody
I am analysing a flow over a special geometric body. i find ridiculous values of drag coefficient.
When i change the momentum value of under relaxation factor to half, drag coefficient changes
What do i expect from changing under relaxation factor?
Is it safe to change them in order to get the expected results?
Thank you
Old   June 1, 2005, 14:10
Default Re: Under-relaxation Factors
pUl|
Judge your convergence by monitoring the drag coefficient at a specific point/surface in your domain. If your flow is steady, then wait for the monitor to level off or exhibit steady fluctuations about a steady value. That will indicate convergence. Theoretically, converged results are independent of the Under Relaxation Factors chosen.
Old   June 1, 2005, 15:10
rachid
To expand the problem, i can say that i already know the drag coefficient value of the shape from the literature. The value that fluent gives me is different (applying the standart procedure of aerodynamic analysis).
I think you meant the drag coefficient should not change with the und. rel. fac. ,but it does...I came across satisfying result with some under rel. factors with manually changing (the momentum value).
Thanks for answering by the way.
Old   June 1, 2005, 19:11
Saad
You may reduce the tolerance for the residuals by 10 or 100 times to get better results.
Saad
Thread Tools
Trackbacks are On
Relaxation Factors for Transient solvers philippose OpenFOAM Running, Solving & CFD 19 March 20, 2014 05:39
Purpose of relaxation factors Mohsin FLUENT 5 April 30, 2010 11:57
relaxation factors and time accuracy Mike Main CFD Forum 7 May 21, 2005 12:41
Relaxation Factors Tim Phoenics 3 June 30, 2004 02:03
relaxation factors adjust zhujianguo Phoenics 1 July 15, 2003 11:11
