Specifying turbulent intensity
Old   June 1, 2005, 20:50
Default Specifying turbulent intensity
ken
hi I'm simulating turbulent flow in a rectangular channel with a circular inlet. Physically, the circular inlet allows connection to a pipe/tube.
The fluid is conveyed either by a positive displacement screw pump or a diaphragm pump. My question is, what turbulent intensity and length scale shoud I specify?
Old   June 1, 2005, 22:37
Default Re: Specifying turbulent intensity
us
I think it's appropriate to use Intensity and Hydraulic diameter option to specify turbulence boundary quantities. You know the hydraulic dia. and turbulent intensity is roughly equal to 4 for Reynolds number of 50000. Regards, -US
Old   June 1, 2005, 22:46
ken
Thanks. Is there a relation between inentsity and Re? My Re ranges from laminar to 12,000.
Old   June 2, 2005, 01:28
pUl|
http://www.fluentusers.com/fluent61/...e178.htm#26307
Old   June 2, 2005, 01:34
ken
I'm not a registered user... can't register as I'm not the license admin...
Old   June 2, 2005, 02:40
pUl|
Check your email.
Old   June 2, 2005, 02:50
ken
Thanks!
How to calculate Turbulent Intensity? prem FLUENT 10 September 29, 2018 09:46
k-epsilon: Defining turbulent intensity and length scale? klausb OpenFOAM 0 January 23, 2011 07:28
Turbulent intensity for pressure Outlet Boundary condition Mohsin FLUENT 1 April 30, 2010 10:36
Turbulent intensity swe704 Main CFD Forum 0 November 13, 2009 03:42
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
