June 6, 2005, 04:15 |
supersonic/initial guage pressure
1. What is the differnce b/w the total pressure and the supersonic/initial guage pressure?
2. From where I can get the supersonic/initial guage pressure? |
June 6, 2005, 05:46 |
Re: supersonic/initial guage pressure
supersonic/initial gauge pressure is only used during initialization to push flow in correct direction. Later it doesn't inlfuence on sollution. Corresponding to the value of this pressure: i usually set in a little bit larger that outlet pressure. For example, if you set outl. stat. press. to 100kPa the initial pressure set 105kPa.
February 22, 2016, 02:51 |
atikah_121
Rep Power: 11 |
Hi michal,
My inlet is velocity inlet, while outlet is pressure outlet. So, should I put any value in supersonic/initial gauge pressure column..? Or I just leave it empty. tq. |
February 22, 2016, 05:15 |
arshia
Rep Power: 10 |
you can set the value of supersonic/initial gauge pressure the same as your outlet pressure
February 22, 2016, 20:36 |
atikah_121
Rep Power: 11 |
tq hamed1987
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 11:35 |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 17:19 |
pressure BC-natural convection | engahmed | Main CFD Forum | 0 | June 16, 2010 11:38 |
supersonic/initial pressure | Ynot | FLUENT | 0 | May 10, 2006 14:23 |
