June 8, 2005, 16:05 |
Command Line vs. GUI Menus
I have a most intriguing experience to relate. I have a simple flat plate model that includes a UDF for two additional UDS's, four UDM's, and an Adjust function. After reading in the mesh and compiling the UDF, I activate the user defined scalars, UDM's and adjust function. I then wish to activate source terms in my "fluid" boundaries. When I activate the 2 UDS's using the GUI menu, I have no problem activating source terms in my boundary conditions using either the GUI or the command prompt. However, when I activate the 2 UDS's using command lines at the command prompt, I get the following error when trying to incorporate source terms in the boundary conditions.
Error: RP_Get_List_Ref: invalid list Error Object: () I get this error whether I am activating source terms in my boundary conditions using either the GUI or the command prompt. I've played around with this for a while and the problem seems to be contained to activating my UDS via the command prompt (and not the UDM's or Adjust function). I'm 99% confident I'm activating my UDS via the command prompt, for everything checks out in the GUI afterwards. Any ideas what may be causing this issue or has anyone encountered a similar problem? regards DAVID |
TUI Commands from GUI? | Carlos | FLUENT | 6 | May 22, 2013 18:05 |
No font in Gambit GUI menus | Gijsbert Wierink | FLUENT | 0 | October 8, 2008 04:25 |
creating plane with text menus | Jenifer | FLUENT | 0 | May 20, 2005 15:41 |
GUI window settings | cmv | Siemens | 0 | February 7, 2005 06:22 |
Resizing GUI menus | D Harvey | FLUENT | 1 | May 4, 2004 19:30 |
