June 7, 2005, 06:50 |
Dynamic Mesh setup problem
Hi all, I am trying to set up a simple dynamic mesh problem. I want to model a 2D pipe in which a zone at the inlet moves upwards, which effectively closes the inlet of the pipe after a set time. I am using the in-cylinder model and I have prescribed identical rigid body motion for the walls and grid of the moving area and specified an interface between the moving and non moving zones. When I try to solve the mesh motion it Fluent gives me the follow message Error: Compute-node-normal: Degenerate faces. Can someone please advise me on the correct way to set up the problem. Thanks in advance, jim
June 8, 2005, 09:26 |
Re: Dynamic Mesh setup problem
What dynamic mesh model (layering, smoothing , remeshing) do you use? I think you don't have prescribe motion for grid, just for walls.
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
CFD-3D flow problem using Dynamic mesh method. | Sar_mech | FLUENT | 1 | November 27, 2008 21:17 |
Problem with Dynamic Mesh and Fluent | Claude | Main CFD Forum | 0 | December 12, 2006 06:03 |
Dynamic mesh problem | Sampath | FLUENT | 1 | October 13, 2004 06:44 |
