Home > Forums > FLUENT
microfluid mixing
Old   June 10, 2005, 12:42
Default microfluid mixing
hi i am not able to model mixing of two fluids in a microchannel using fluent6.0.i use the species transport mode.but every time the channel is initially filled with one of the fluids as in case of simulating an ic engine combustion.what i want is that the channel should be empty initially. please help me. thank you
Thread Tools
Trackbacks are On
mixing plane model: too much backflow and does not converge sbhi FLUENT 1 December 4, 2014 01:31
Problem with Mixing plane Mitpostdoc FLUENT 0 July 26, 2011 14:31
Meshing a Mixing Plane in ICEM Will Anderson ANSYS Meshing & Geometry 2 November 9, 2010 10:16
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 18:08
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 08:16
