June 10, 2005, 12:42 |
microfluid mixing
hi i am not able to model mixing of two fluids in a microchannel using fluent6.0.i use the species transport mode.but every time the channel is initially filled with one of the fluids as in case of simulating an ic engine combustion.what i want is that the channel should be empty initially. please help me. thank you
mixing plane model: too much backflow and does not converge | sbhi | FLUENT | 1 | December 4, 2014 00:31 |
Problem with Mixing plane | Mitpostdoc | FLUENT | 0 | July 26, 2011 14:31 |
Meshing a Mixing Plane in ICEM | Will Anderson | ANSYS Meshing & Geometry | 2 | November 9, 2010 09:16 |
Meshing a Mixing Plane using ICEM | Will Anderson | FLUENT | 0 | November 6, 2010 17:08 |
Mixing plane geometry definition | Hbet | FLUENT | 0 | January 18, 2002 07:16 |
