Flow in porous media
Old   June 7, 2005, 14:17
Default Flow in porous media
Anitha
Hi all,
I have a cylinder, open to atmosphere, consisting of two layers of different porous media each.Water flows in the cylinder at a very low rate. The viscous resistances in the two layers are such that one is 10^4 times the other.In the velocity contours,I expect to see higher velocity in the layer with less viscous resistance.But in the contours I see that velocity in the cylinder is same throughout.
I give velocity-inlet B.C. for the top face, pressure-oulet B.C. for the bottom face and wall B.C. for the side of the cylinder.I enable porous zone option for each of the two layers
why is this happening? Any idea?
Anitha.
Old   June 7, 2005, 16:03
Default Re: Flow in porous media
Prakash Verma
Use physical velocity formulation in solver settings. I think you have used Superficial velocity.
-Prakash
Old   June 7, 2005, 18:51
Anitha
Hi Prakash, I tried it, but of no use Its still giving same velocity throughout By the way do resistance coefficients affect the velocity?If so,how?
TIA Anitha
Old   June 8, 2005, 00:38
Prakash Verma
hi Anitha, yes resistance coefficients affect the velocity. You have to supply viscous and inertial resistance coefficients. note that viscous resistance coefficents is 1/alpha (You have to specify it) ==> lower the coefficient means higher the resistance which results in higher velocity. For more help read the manual to calculate these coefficients which depend on particle size.
hope it helps -Prakash
Old   June 9, 2005, 07:33
korni
Hi Anitha!
If you cylinder has only one diameter, then it's correct that the velocity is the same (at least if it has side walls) because of the continuity... same mass flow and flow surface - same velocity...
But the pressure drop will be higher in the area with the higher resistance...
check that..
sorry for my poor english!
korni
Old   June 9, 2005, 12:22
Thiyaga
Go for pressure inlet and pressure outlet BC if u kno pressure drop. then u can c variable velocity. regards.. Thiyaga.
Old   June 11, 2005, 05:22
Sudheendra
hi Thiyaga,
As I have said earlier, my cylinder is placed in open space so that pressure at the inlet and pressure at the outlet is also the same i.e. 1 atm.Infact I have tried this out but there is no flow at all.
So I started giving velocity-inlet at the inlet (since I know the incoming flow-rate) and pressure outlet at the bottom
What do you say?
Regards, Anitha.
Old   June 11, 2005, 05:23
Anitha
hi Thiyaga,
What do you say?
Regards, Anitha.
Old   June 13, 2005, 12:56
Thiyaga
there should be some pressure gradient, then only flow will occur through the porous media, calculate the value of pressure drop with Darcy's eqn (6.19.5 of Fluent6.1 manual), i think u know the value of permeability and velocity.use P(inlet)=P(outlet)+del P. hope this would help. regards Thiyaga.
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 10:34
Compressible flow through porous media? JoFFe CFX 2 November 1, 2010 04:50
no converge - for Low Re Porous media seepage flow lee CFX 3 August 31, 2007 01:12
Modeling porous media flow in prostar Nirmal Kumar Pathak Siemens 8 November 23, 2005 07:18
Flow resistance of porous media Desheng Kong Main CFD Forum 3 December 19, 2000 11:07
