"error message:negative volumes exist"
Old   June 18, 2005, 10:39
Default "error message:negative volumes exist"
hash
hello friends; i m making modeling for flow around the moving car.i made mesh around the car while running in fluent during grid check it gives an erroe message that negative volume exists.can u please give any info about it? what kind of problem it is ?
Old   June 19, 2005, 00:44
Default Re: "error message:negative volumes exist"
Mehdi Ghoddosy
Dear Hash:
Negative volume means that some cell on your grid are overlapped and/or disattached. Means improper connectivity. You can eliminate this problem using Iso-value adaption. However if you want to see these cells use adaption->iso-value->mark.
Regards
Old   June 19, 2005, 01:38
Masood
hi i faced the same problem when tried to mesh with a larger mesh size than a small dimension in geometry. i remshed and problem is loved. but as MEHDI said Iso-value adaptation, what fluent do to the mesh to remove -ve volumes. isnt remeshing is more appropirate. because i got only 1 -ve vloume and funny thing i can not see it. so i remshed
Problem with Volumes Gambit Danath ANSYS 1 October 19, 2011 08:20
"Warning: non-positive volumes exist" lordvon FLUENT 0 April 22, 2011 15:49
[GAMBIT] Connecting volumes makaero ANSYS Meshing & Geometry 4 April 15, 2010 19:18
negative grid volumes when adapting Dave FLUENT 1 August 20, 2005 13:47
union of volumes CHUBBY FLUENT 2 May 4, 2001 06:31
