Home > Forums > FLUENT
Dynamic mesh - again
Old   June 14, 2005, 04:58
Default Dynamic mesh - again
Antoni
I need help !!! I am combining and nothing.
I have four wall:
wall-1
______________
| | wall-2 | | wall-3
______________
wall-4 If it's possible to moving wall-4 (direction to wall-1) without uses UDF file. Which walls is stationary and moving. And which parameters in "Dynamic Mesh" I must determine???.
Regards
Old   June 15, 2005, 05:28
Default Re: Dynamic mesh - again
Antoni
Sorry, but my schematic is not clear. This is square which consist od four walls (top - wall1, bottom -wall4, left -wall2, right-wall3).
Regards
Old   June 15, 2005, 10:56
Rafael
only wall-4 you don't need use stationary set layering
you can use in-cilinder for tests or try this udf
#include "udf.h"
static double linear;
DEFINE_CG_MOTION(linear, dt, vel, omega, time, dtime) { real w = 300,a=0.1;
NV_S (omega,=, 0.0);
linear = w*sin(w*CURRENT_TIME); vel[0] = linear; }
0 is the direction of moving
0 is x 1 is y 2 is z
Old   June 16, 2005, 04:44
Antoni
Hi
But I cannot compiled:
..\..\src\pist.c(8) : error C2373: 'linear' : redefinition; different type modifiers
..\..\src\pist.c(4) : see declaration of 'linear'
Regards
Thread Tools
Trackbacks are On
Incylinder dynamic mesh with volumetric reaction mas FLUENT 4 May 3, 2012 10:22
Dynamic Mesh on Pintle type injector. herntan FLUENT 15 January 4, 2012 04:31
pls help. mesh collapsed with dynamic mesh. wlt_1985 FLUENT 1 July 28, 2011 01:53
dynamic mesh on a hexa grid Manoj Kumar FLUENT 0 August 21, 2007 07:41
Dynamic mesh + grid adapt = Crash! (Files included BillH FLUENT 4 July 24, 2007 15:31
