3D Mesh generation of BFB with Internal Tubes
Old   June 14, 2005, 17:37
Default 3D Mesh generation of BFB with Internal Tubes
SANJIB KUMAR DAS SHARMA
I would like to generate a boundary layer on a cylinder inside a 3D geometry. In this way I can reduce the number of grids. However, I was unable to generate the boundary layer. Can anyone suggest ?
Thanks,
Sanjib
Old   June 19, 2005, 00:05
Default Re: 3D Mesh generation of BFB with Internal Tubes
Mehdi Ghoddosy
Dear Sanjib:
You can split the heading circle into for curves at 45 degree.Then change these vertex types to END. THen split the curves on the top and bottom at +90 and -90.Now you have 6 curves. grade the four edges in the top and botom to achive finer mesh at corners. Now you can mesh these circle using map scheme. and then mesh the cylinder using cooper scheme.
REgards
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[ANSYS Meshing] Huge Mesh generation. sahm ANSYS Meshing & Geometry 7 June 12, 2011 18:39
Mesh generation software is needed H.Dou Main CFD Forum 12 May 4, 2011 15:20
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
3-d elliptic generation mesh Gang Sun Main CFD Forum 5 September 16, 1998 00:24
