Home > Forums > FLUENT
UDF problem...
Old   June 15, 2005, 09:08
Default UDF problem...
Laura
For transient calculations of a non reacting system with 2 inlets (one for gas A and one for gas B) and one outlet for a mixture A+B,
I have to report the mass fraction of B as a function of time step for all the cells at the outlet.
Any one know hows to start/writte an UDF to make that possible?
I tried to use your udf that cg suggested to me as an interpreted one but I got the following error message :
cpp -ID:\FLUENT.INC\fluent6.0/src -ID:\FLUENT.INC\fluent6.0/cortex/src -ID:\FLUENT.INC\fluent6.0/client/src -ID:\FLUENT.INC\fluent6.0/multiport/src -I.
-DUDFCONFIG_H="<udfconfig.h>" C:\FLUENT\projects\udf.cError: C:\FLUENT\projects\udf.c: line 11: parse error. Error: C:\FLUENT\projects\THALES\udf.c: line 20: f_loop_last: undeclared variable
I tried also to use it as a compiled one and got the following error message : Opening library "libudf"...
Error: open_udf_library:....
is there a path problem?
Here is the udf :
______________________________________
#include "udf.h"
DEFINE_ON_DEMAND(species_mass_flow) {
Domain *domain = Get_Domain(1);
Thread *t; face_t f;
thread_loop_f(t,domain);
real f
real smf
if( THREAD_TYPE(t)==THREAD_F_POUTLET )
begin_f_loop (f,t)
real smf = F_FLUX(f,t)*F_YI(f,t);
end_f_loop(f, thread)
Message("%i %e\n",f,smf);
end_f_loop (f,t) }
_________________________________________
any one can help ? Thanks.
Old   June 15, 2005, 11:21
Default Re: UDF problem...
Alec Eiffel
Hi Laura
There is a couple of syntax errors in UDF. Try compiling this version
#include "udf.h"
real smf;
int species_index = 0;
begin_f_loop (f,t)
smf = F_FLUX(f,t)*F_YI(f,t,species_index);
you might have to change the species index depeding on which you want to report. hope this helps!
Old   June 16, 2005, 04:43
Laura
Hi Alek !
Thanks for the answer.
I still get the same error when i compile my udf: Opening library "C:\FLUENT\projects\libudf"... Error: open_udf_library: Le fichier spécifié est introuvable (that means : file not found).
If you agree I can send you my case\data file and the udf (but I don't have your email adress? or may be you prefer to contact : rumba5@voila.fr ?).
May be you can check it if you have time.
Many thanks in advance.
Laura.
Old   June 16, 2005, 06:05
Laura
Error when I compile my udf as interpreted :
cpp -ID:\FLUENT.INC\fluent6.0/src -ID:\FLUENT.INC\fluent6.0/cortex/src -ID:\FLUENT.INC\fluent6.0/client/src -ID:\FLUENT.INC\fluent6.0/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" C:\FLUENT\projects\fraction.cError: C:\FLUENT\projects\fraction.c: line 19: structure reference not implemented
any help please?
Old   June 16, 2005, 08:34
Mahesh
variables in () of f _loop are not matching.
Old   June 16, 2005, 09:05
Laura
what do you mean please?
Old   June 16, 2005, 15:12
dirk
you declare the variable smf twice (in lines 7 and 11) and there are some semicolons missing. By the way: can't you do this report with a surface integral ?
Dirk
Thread Tools
Trackbacks are On
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 32 May 8, 2015 06:05
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 01:31
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF problem chiseung FLUENT 4 January 10, 2002 10:58
