interpreted udf compile
There is a interpreted udf example which is compiled wrong as following:
cpp -ID:\FLUENT~1.INC\fluent6.1.22/src -ID:\FLUENT~1.INC\fluent6.1.22/cortex/src -ID:\FLUENT~1.INC\fluent6.1.22/client/src -ID:\FLUENT~1.INC\fluent6.1.22/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" D:\Work\fluent work\water bubble\90\inlet.c Error: D:\Work\fluent work\water bubble\90\inlet.c: line 1: parse error. anyone can help me with this? Thanks a lot! |
Re: interpreted udf compile
I'm not sure but I think that the path to your UDF should not contain any spaces i.e. eliminate spaces in : "..\fluent work\water bubble\".
Regards, David |
thank you very much! i will try it
