UDF in Parallel
Old   June 16, 2005, 11:06
Default UDF in Parallel
Gavin
I am using parallel computing on two Windows XP Pro. I compiled my UDF in Parallel Fluent with 2 nodes enabled. Log tells me that the compilation is successful. When I load the UDF library, Fluent hangs on for ever.
If I spawned two nodes on one of computer (i.e. using SMP), the UDF can be loaded successfully.
I shared the working directory where UDF is located. It still does not work. Anyone could please give me some advice?
Thanks,
Gavin Yang
Old   June 19, 2005, 22:17
Default Re: UDF in Parallel
kk
hello.
I had same problem when rshd setting was wrong.
I don't know it so much, but User's guide(32.4.1) might help you.
good luck!!
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
udf compile in parallel system tahereh FLUENT 1 December 9, 2008 09:48
Help: how to realize UDF on parallel cluster? Haoyin FLUENT 1 August 6, 2007 13:53
Parallel Fluent +UDF Jack Martinez FLUENT 0 June 28, 2007 11:19
UDF in parallel version. yobee FLUENT 0 August 17, 2004 04:12
