CPU requirements
Old   June 13, 2005, 08:04
Default CPU requirements
aPpA
Hi.. Can someone tell me what kind of cluster would I be needing to solve a 3D, gas-liquid flow in a geometry with a grid of about 150,000 cells using FLUENT 6.2. The equations I need to solve for are flow, vof, turbulence, Mass transfer and probably population balances by UDF. Any sources where I can find this information will also be helpful. Thanks in advance
Old   June 19, 2005, 00:21
Default Re: CPU requirements
Mehdi Ghoddosy
Dear aPpA:
I have sloved a problem like yours with 179,000 non-conformal grid; RNG k-e model; two layer wall treatment; VOF and QUICK descretization scheme. I have and AMD sempron 2500+ CPU with 512MB 444mhz ram. I takes about 8 hours to run 6000 iteration and get good results. Ready for more help if you need.
Regards
Old   June 19, 2005, 00:24
Mehdi Ghoddosy
Dear aPpA:
Forgotted to say: 512 MB to maximum 1GB memory is enough for your problem. try to enhance you CPU. Also graphic card is important for posr processing
stop when I run in parallel Nolwenn OpenFOAM 36 March 21, 2021 04:56
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
OpenFOAM 13 Intel quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 13 February 5, 2008 05:26
OpenFOAM 13 AMD quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 1 November 10, 2007 23:23
Dual Core CPU hjasak OpenFOAM Running, Solving & CFD 5 July 22, 2006 03:57
