reverse flow at outlet
Old   June 17, 2005, 04:15
Default reverse flow at outlet
Neil
Dear all,
Does anyone know how fluent deals with reverse flow at a pressure outlet for compressible flow? Is it true that the "pressure outlet" condition switches to become a "pressure inlet" condition, with the specified static pressure specified for the outlet condition being assumed to be the total pressure at the for the inlet condition when the flow is reversed?
Thanks for your help.
Neil
Old   June 22, 2005, 00:49
Default Re: reverse flow at outlet
Gamma23
Reverse occured because fluent detect there is a opposite vector in the velocity profile. I suggest if you to extend the outlet to provide more computation domain so that the flow can achieve fully developed flow mode.
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
Mass flow inlet and pressure outlet issue nikhil FLUENT 5 December 11, 2013 12:30
CAN'T CONVERGE WITH REVERSE FLOW AT OUTLET! XIAOYI LI FLUENT 11 September 14, 2012 16:43
CFDesign V11 -- Reverse flow at outlet maruthiv Autodesk Simulation CFD 1 June 17, 2011 09:38
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
