Home > Forums > FLUENT
UDF_unsteady
Old   June 22, 2005, 04:53
Default UDF_unsteady
Akbar
Dear Sir
I am doing unsteady analysis of nozzle, pressure at inlet is varying from 10 bar to 1 bar from 0 to 2 sec.
I wrote udf's for total pressure and supersonic/ initial gauge pressure at inlet. But fluent define only one udf at a time.
when i define second udf, firstly define udf was disappeare from the memory.
How can I define time verying profile of total pressure and supersonic/ initial gauge pressure at inlet?
For an unsteady problem, at a point in flow domain, I am looking to draw plot of a property (mach number , velocity etc.) vs time.
Is it possible to draw plots of properties vs time? If possible, please guide me.
Thanks & Regards
Old   June 22, 2005, 10:25
Default Re: UDF_unsteady
david
hi,
Just create a point surface of the precise location you want to monitor by exploring surface/point. Once this surface is created, create a monitor of the quantity you wish to monitor under solve/monitors.
Unless you to monitor some special quantity not available in Fluent, you do not need a UDF for this.
Hope this helps David
Old   June 22, 2005, 13:29
dirk
You have to put all your UDFs into one file.
Old   June 23, 2005, 05:56
Akbar
thanks its working
Old   June 23, 2005, 06:03
Akbar
Its working, thanks.
I am doing analysis of a nozzle , solution is going to converge at inlet pressure 45 bar & outlet pressure 1 bar, but it is going to divarge when i am imposing inlet pressure around 5 bar.
for same geometry and same boundary condition why its happening? I think flow physics become so complex, so fluent diverge.
May yoy help that how can I get a converge solution at low pressure inlet?
Old   June 23, 2005, 06:04
Akbar
Thanks its working.
May you help that how can I get a converge solution at low pressure inlet?
Thread Tools
Trackbacks are On
