June 24, 2005, 03:05 |
running gambit
hi i tried to install fluent6.0 on win 2000.whenever i run gambit i get message "unable to open display". but same installation process on win XP does not have any problem.
June 24, 2005, 10:38 |
Re: running gambit
I get the same message, but if you let it run, GAMBIT opens eventually. If not try removing the old default_id files and GAMBIT folder created in your run directory. It might also be your Xclient installation.
[GAMBIT] Canīt start GAMBIT | zalho | ANSYS Meshing & Geometry | 18 | April 8, 2019 01:05 |
[GAMBIT] Close Gambit | L3munoz | ANSYS Meshing & Geometry | 0 | September 18, 2010 06:39 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Athlon 64 Gambit Compatibility? | Derick | FLUENT | 3 | January 17, 2006 17:28 |
Generating big meshes with GAMBIT on NT | Andrew Ooi | FLUENT | 12 | February 2, 2000 22:26 |
