Home > Forums > FLUENT
Fan Modeling
Old   June 24, 2005, 03:43
Default Fan Modeling
shraman
Hi, I need to select a fan for particular model. I have specified constant pressure jump at the fan face and got the computed mass flow values through fluent. The curve seems to be increasing flow with increasing pressure ratio. But the manufacturer's specification gives pressure jump vs flow rate, which seems to be increased flow rate with decreased pressure. Any idea how do I convert my data to manufacturer's type of data? Regards.
Old   June 24, 2005, 16:04
Default Re: Fan Modeling
Nish
Shraman, I dont have a solution for this but infact I have the same problem. I specified a constant pressure rise across a fan face and the velocities are higher, which means, if the area across the fan face is constant then the flow rate is higher due to high velocities. However, when I look at the manufacturer specified fan curves, at lower flow rates the pressure is higher. If you are able to come across a solution to this, please let me know why this happens. Regards, Nish
Thread Tools
Trackbacks are On
Modeling a Fan by the Multiple reference frame (MRF) method in CFX. saisanthoshm88 CFX 9 February 15, 2016 01:01
Fan Modeling in Fluent L. Hamid FLUENT 0 May 24, 2011 02:22
fan modeling in STAR-CCM+ Martin CD-adapco 2 December 27, 2010 05:02
Modeling of centrifugal fan in CFD Simon Williams Main CFD Forum 3 February 20, 2009 16:00
modeling a fan tony CFX 0 February 13, 2008 17:45
