Error
Old   December 17, 2007, 21:03
Default Error
wengkit
Error: prf-set-var:invalid flonum Error Object: nan0x7ffffe00 wat does this erro mean?
Old   November 22, 2016, 01:21
Default Cylinder
sanju
sanjeevkumar patne is on a distinguished road
I too have the same problem.
I just considered the cylinder and given inlet velocity at one side and outlet pressure at the other side.
1. defined the surfaces as the temperature body
2. inlet air velocity 8 m/s.
3. trying to find the cooling response of the system.
In cell zone BC
when I define cylinder as fluid then there was no error, but I defined it as solid the error was showing as below
Error - %prf-set-var: invalid flonum
Error object - 1.£ inf
Kindly anyone suggest what is the problem.
Thanks in advance.
sanjeevkumar patne is offline   Reply With Quote
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
