FLUENT FUEL CELL MODEL
Old   June 24, 2005, 11:33
Default FLUENT FUEL CELL MODEL
BC
Hi,All I am using FLUENT Fuel Cell Toolbox to model a single PEM fuel cell stack.When I tried to initialize the model, I got the following error messages. Error: prf-set-var: invalid flonum Error Object: nan
Anyone knows how to solve the problem? Does that mean that I didn't specify all the required material properties correctly? I am desperate. Please help!
BC
Old   January 30, 2010, 02:52
Philip Mprezas ( f.mprezas@yahoo.gr )
karmagos is on a distinguished road
what version did you use?
karmagos is offline   Reply With Quote
Old   July 12, 2011, 19:25
Default Same issue
Shrinivas
shrinivaslokare is on a distinguished road
I have the same problem when I modified a case in fluent 13.0 and tried to read it in Fluent 12.1.4. I checked the case file is good by opening it in Fluent 13 multiple times. But with Fluent 12.1.4, it gives the same error message:
"Error: %prf-set-var: invalid flonum"
Any clue whats going on?
Thanks.
Shrinivas
shrinivaslokare is offline   Reply With Quote
Old   July 7, 2013, 11:59
Roberto Meloni
Roberto Meloni is on a distinguished road
Hi guys,
Did anyone fix this fluent bug?
I'm running a simulation on Ansys 13 of an internal combustion engine and when I try to load the .cas and .dat files saved every 15 time step, this error message appears.
Thanks in advance.
All the best.
Rob.
Roberto Meloni is offline   Reply With Quote
Old   May 17, 2014, 18:27
YuHuo
AlexHo is on a distinguished road
Probably because of the different version of Fluent.
AlexHo is offline   Reply With Quote
Old   November 22, 2016, 01:23
Default cylinder
sanju
sanjeevkumar patne is on a distinguished road
I too have the same problem.
I just considered the cylinder and given inlet velocity at one side and outlet pressure at the other side.
1. defined the surfaces as the temperature body
2. inlet air velocity 8 m/s.
3. trying to find the cooling response of the system.
In cell zone BC
when I define cylinder as fluid then there was no error, but I defined it as solid the error was showing as below
Error - %prf-set-var: invalid flonum
Error object - 1.£ inf
Kindly anyone suggest what is the problem.
Thanks in advance.
sanjeevkumar patne is offline   Reply With Quote
Old   November 22, 2016, 01:24
sanju
I am working in ANSYS Fluent 15 version
Fuel cell Rekha FLUENT 10 September 27, 2018 07:52
Fluent on Cell Processor DC FLUENT 2 March 14, 2008 12:01
Questions about Fuel cell model braket FLUENT 0 March 17, 2007 19:37
