Uniting faces in Gambit
Old   June 24, 2005, 13:16
Default Uniting faces in Gambit
AJG
I have a complex geometry that I imported from Pro-e to Gambit, this geometry came with several faces and I want to simplify them by uniting them because it will be easier for me to specify the boundary conditions for less faces. How can I unite these faces to form one face? these faces are not intersecting with each other, they just share one boundary, is like having a fence formed by sticks and what I want to do is join all the sticks to form a simple face.
thanks
Old   June 24, 2005, 18:09
Default Re: Uniting faces in Gambit
dirk
I think you don't need to unite these faces. You can define one boundary zone, that contains all the faces.
Old   June 27, 2005, 03:56
edi ghirardi
You can use the "merge faces" command, but it will turn them into a virtual face, which is generally not raccomandable. Dirk's suggestion is still the best. If you can, try to simplify your CAD model.
Edi.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
