Home > Forums > FLUENT
LES - periodic PLEASE HELP!!!
Old   June 25, 2005, 03:33
Default LES - periodic PLEASE HELP!!!
Al
Hi, I'm trying to LES a sector (say 30deg) of an annulus. The flow is in X-direction. Is it OK to define periodic BC on the two faces inclined to each other by 30deg (i.e. those parallel to X-axis)? Should a special care be taken due to the fact that these faces are rotationally periodic? If yes, then how I should do it? Can it be done in Fluent without modifying the mesh? Should I check the "reversed" box in Gambit while linking the two faces in question? Thanks a lot.
Old   June 28, 2005, 07:48
Default Re: LES - periodic PLEASE HELP!!!
Indi
Fluent should be able to do it without modification (assuming its LES mode does work!). And yes you have to click reversed box in Gambit. Since version 2.0, the reverse button is set as default by Fluent Inc.
Old   June 29, 2005, 11:24
Al
Thanks a lot. I've managed to do it.
Thread Tools
Trackbacks are On
periodic boundary condition in LES martor FLUENT 2 April 10, 2012 19:17
Statistic averaging and Periodic BC Fluent/Gambit truffaldino ANSYS 0 July 5, 2011 18:55
LES of periodic pipe centerline turbulent kinetic energy smehdi609 OpenFOAM 0 December 1, 2010 00:59
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 10:58
