June 12, 2005, 23:50 |
Can Fluent deal with complex number?
Can fluent(udf) calculate the complex number as following: (1+i)^(1/3)?
does it work? pow(1.0+i,1.0/3.0)? Thanks. And how can I get the real part of a complex number in udf? |
June 13, 2005, 03:52 |
Re: Can Fluent deal with complex number?
If you use scheme language the answer is yes. If you want to write a UDF you can add external libraries. Luca
June 27, 2005, 03:53 |
Thanks a lot
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
Obtaining Reynolds Number in FLUENT | Emmanuel | FLUENT | 2 | April 7, 2016 01:46 |
mach number and selection of the fluent solver | turbinesv | FLUENT | 4 | April 24, 2011 00:14 |
Fluent 12.0, Low Reynolds Number Flows | anandvksin2003 | FLUENT | 1 | January 26, 2010 05:16 |
Fluent 6.4 courant number | Aris Nikolopoulos | FLUENT | 0 | May 6, 2008 08:52 |
