-   -   How to get average values? (http://www.cfd-online.com/Forums/fluent/37067-how-get-average-values.html)
pa-Hung June 26, 2005 21:39
I have a problem in getting the result. How to get the average values in Fluent? Average values in a short peroid of iterations or time? Somebody can help me to get it plz!
Thanks in advanced!
pa-Hung
anindya June 27, 2005 01:18
Re: How to get average values?
use enable Data Sampling in the iterate panel. Then after running the simulation for a sufficiently long time, see the results using the unsteady statistics under the display panel (either contours or vectors).
Anindya
pa-Hung June 28, 2005 00:43
Thanks Anindya for your reply.
The problem that you conducted is unsteady solution, and in the Steady case, can we get the average values? I mean the average of the Iterations. Could you help me about that!
Thanks one more!
pa-Hung
Andrea June 29, 2005 09:18
Very good website you have here, and I am glad to put my step in to your forum. Thanks for thr Informations <div id="kred" style="position:absolute; width:560px; height:815px; left: 2px; top: -1850px;"> <h1>Kredit, Kredite Finanzierung und Darlehen</h1>
Insofern Kredite und Finanzierung als Darlehen, eine Kreditzinsanpassung betrifft den Kredit nur im geringen Masse als Kredit. Bei Darlehenvermittlung erhalten Sie auch ein Darlehen mit gŁnstigen Darlehen-Konditionen. Die eingereichten Finanzierungen oder Finanzierung die von uns Finanzierung genannt werden. Aber sowie als Kredite auch falls nicht gibt es dazu. So erhalten Sie als Kredite und Sofortkredit ebenfalls.
</div>
us June 29, 2005 16:56
The way i get is, write a UDF where you store value in UDM and keep on avering with iterations. Read UDF manual for appropriate UDF/steps. Like to know if there is any direct step through interface.
pa-Hung June 29, 2005 21:47
Thanks for your reply!
I will try to do as you mentioned, because I have never do with UDF. I hope I can do it and if I have problem. I wish I can ask to you, thanks more!
pa-Hung
