Herschel Bulkley panel
Old   July 19, 2005, 14:37
Default Herschel Bulkley panel
Hengky Harmita
Has anyone ever used Herschel Bulkley panel for viscosity. I have had a problem to select that model under material panel. When i clicked on the drop down list of viscosity model, that model was not available in fluent 6.2. I was wondering if somebody could help me how to select that particular model and put it into as viscosity equation. Thank you in advance
Old   July 20, 2005, 03:50
Default Re: Herschel Bulkley panel
HVN
The Hershel Bulkey model is not available if you have already selected a turbulent model.
If you want to use a turbulent model, you need to select before the hershel model and then through the command line to activate the k-e model.
HV
Herschel Bulkley model Problem emad FLUENT 6 September 12, 2018 13:35
Yielding viscosity for Herschel Bulkley model Godwin FLUENT 1 December 12, 2011 05:42
automatization herschel bulkley hamina FLUENT 0 February 22, 2006 05:44
automatization herschel bulkley hamina FLUENT 0 February 22, 2006 05:41
otomatization herschel bulkley into fluent hamina FLUENT 0 February 21, 2006 10:45
