-   -   How to get each cell value into a text file (http://www.cfd-online.com/Forums/fluent/37077-how-get-each-cell-value-into-text-file.html)
Wiroon June 28, 2005 01:51
Dear All,
I am considering mixing of two components inside a 2D-closed geometry where I move its sidewall to trigger internal recirculation. I want to calculate deviation change of concentration with time to evaluate mixing intensity. However, I don't know how to get a value of cell concentration cnd cell grid size from each cell into a file for deviation calculation. Is there a function in Fluent that helps calculating deviation? If anyone knows, please help me.
peter June 28, 2005 09:14
Re: How to get each cell value into a text file
To put each cell centroid, species mass fractions and cell volume into a text file, try to compile and then hook as an execute at end UDF something like the following:
DEFINE_EXECUTE_AT_END(All_Out)
{ Domain *dom= Get_Domain(1); /* returns fluid domain pointer */
int index0=0;
int index1=1;
real c0;
real c1;
real cv;
Thread *c_thread ;
real x[ND_ND];
cell_t c;
FILE *fp; /* define a local pointer fp of type FILE */
fp = fopen("data.txt","a"); /* open a file named data.txt in
append mode and assign it to fp */
thread_loop_c(c_thread, dom) /*loops over all cell threads in domain*/
begin_c_loop(c, c_thread) /* loops over cells in a cell thread */
c0=C_YI(c,c_thread,index0);
c1=C_YI(c,c_thread,index1);
cv=C_VOLUME(c,c_thread);
C_CENTROID(x,c,c_thread);
fprintf(fp, "%g %g %g %g %g\n", x[0], x[1], c0, c1, cv);
end_c_loop(c, c_thread)
fclose(fp); /* close the file pointed to by fp */
Wiroon June 28, 2005 09:35
Dear Peter, Thank you very much for your kind help. I will try to understand the program first and then use it in my simulation.
