fluent output pressure of elements in xyz
Old   July 5, 2005, 22:33
Default fluent output pressure of elements in xyz
Fred
hello, all cfders
There is a problem in output pressure of elements using Fluent.I wanna output the pressure of all the elements of solid, but fluent just only can output the pressure normal to the elements...
it is really bothering me,anyone can do me a favor?
many thanks!
Old   July 13, 2005, 08:06
Default Re: fluent output pressure of elements in xyz
Fred
every one,who can help me!!
thanks!
Old   July 13, 2005, 09:43
Jason
The easiest way is probably going to be to export an ASCII file of the static pressure.
File->Export, change file type to ASCII, choose the surface you want the pressure on, and then select static pressure under functions to write. Make sure "Node" is selected under location so that it interpolates the data right to the surface, otherwise it gives the coordinates and pressure at the cell center.
If you're interested in the data on different surfaces, then you might want to write different files for each surface. I don't think there's a way to export a surface label along with the data (I could be wrong on the surface label though... I only had to do this once, and I had to go back to Fluent to remember how I did it).
Hope this helps, and good luck, Jason
Old   July 16, 2005, 03:51
Fred
thanks jason
maybe UDF could help me...
regards.
high CPU load with no computation going on & Pressure coefficient output problem spetsnaz26 FLUENT 0 September 30, 2011 05:25
Increasing the accuracy of pressure head values in output data Saeed1390 FLUENT 0 June 13, 2011 02:17
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 13:43
How to get the pressure and pressure loss in fluent while using periodic winnawinna FLUENT 1 May 6, 2011 03:44
UDF in Fluent to Match Mass Flow at Pressure Outlet Jonas Larsson Main CFD Forum 1 April 29, 1999 10:44
