Home > Forums > FLUENT
Sliding Mesh
Old   July 5, 2005, 13:51
Default Sliding Mesh
Gopal Kasat
Hi all
I am trying to solve the flow in a stirred tank with Sliding Grid method. While solving the flow, the velocities are not transfering from sliding zone to stationary zone. I think this is the problem because of the modelling of interface. Can anybody help me to know about how to treat the interface between the two zones.
In fluent when you creat interface there are options like period and coupled. Which type of interface should be selected.
Can anybody pls help
Thanks Gopal
Old   July 6, 2005, 02:47
Default Re: Sliding Mesh
michel
1)Should be the same angle , overlapung boundary which may to represent interaces
2) Change in boundary GUI both to the interfaces
3) Create intefrace, with option of periodic enabled
That's all. Somethimes it need a few good iterations to distribute the flow in whole domain , renemember that it is unsteaty and time dependent. It is good idea to initialize flow in whole domain using steady-state approach, make some iterations and then switch to unsteady
goog luck
Old   July 6, 2005, 04:40
Gopal Kasat
Thanks Michel. A small querry agian. I am solving the flow using the whole 360degree domain. It is still necessary to make the interfaces periodic?
Thanks Gopal
Old   July 6, 2005, 05:15
michel
No I dont't think so.
Old   July 8, 2005, 09:41
Gopal Kasat
hi michel
I have tried with the 360 degree geometry with the interface created as you suggested. But still not getting the results.
One thing i want to ask: At the time we creat interface two walls boundry are created. Can you let me know what boundry conditions whould be given to these wall boundary
Thanks Gopal
Thread Tools
Trackbacks are On
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Sliding mesh error alice FLUENT 3 February 21, 2012 06:53
external flow with snappyHexMesh chelvistero OpenFOAM 11 January 15, 2010 20:43
dynamic mesh and sliding mesh nasser FLUENT 0 November 1, 2005 03:37
