[Sponsors] | |||||
hi,
I have generated a mesh trying to use axisymetry to calculate de pressure drop between two circular paralel plates where the flow is radial. I have created de geometry in 2d and i have defined teh boundary conditions with fluent -a velocity inlet -a pressure outlet -an axis (an edge along the x axis) -the walls but when i read the archive in fluent, it recognize all the edges as walls and the edge defined as the axis don't appear when i display the grid any ideas? thanx |
If the edge isn't part of the mesh (i.e. the fluid isn't actually touching the axis of symmetry), it won't show the axis. The only time you need to define the axis is if the flow is touching the axis (when you define it as an axis it treats it like a symmetry BC). Other than that, the axis is going to be the x-axis and your domain must be above the x-axis.
Good luck, Jason |
thanx a lot Jason
my first model is going on! |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 07:21 |
| Boundary conditions for 2D Navie-Stockes simulation | L1011 | OpenFOAM | 5 | December 13, 2012 08:17 |
| Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 24 | January 11, 2012 13:40 |
| Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... | 2 | July 15, 2005 04:15 |
| A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 18:29 |
