July 11, 2005, 12:39 |
bouyancy driven flow
I'm running a case of bouyancy driven flow in a box-test geometry; I've got an upper "pressure outlet" surface and a lower "pressure inlet" surface. Lateral surface are "symmetry" type but in the middle, on one hand, there's a "wall" type surface at 293.15 K. I'm running with only air as compressible ideal gas. The bulk temperature, as the inlet and outlet temperature, is fixed at 373.15K. Operating pressure is 2 bar. Viscosity model is RNG K-e. Is it necessary to use an Enanched Wall Treatment option to take into account correctly the effect of buoyancy near the cooled wall or it's possible to use Standard Wall Function?
July 12, 2005, 12:11 |
Re: bouyancy driven flow
You can use standard wall functions provided you check your y+ values.
is there any parallel code for the famous Lid Driven Cavity flow? | gholamghar | Main CFD Forum | 0 | August 1, 2010 01:55 |
Buoyancy Driven Flow - HELP! | Carlos | FLUENT | 2 | October 11, 2007 02:35 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
bouyancy driven flow | adrienne | CFX | 5 | January 6, 2003 08:55 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
