Mass Flux vs Velocity Inlet
Old   July 18, 2005, 10:09
Default Mass Flux vs Velocity Inlet
Sandra
Hi, I am trying to impose a sinusoidal veloity profile at the inlet using a UDF. Reading more about it I realized that for my case (compressible case) the boundary conditions to be used should be mass flow inlets vs velocity inlets. Would anyone know the difference between the two. In another words can I use the same UDF for the mass flux, considering that mass flux is rho*u*A/A. I'm getting somewhat confused with the UDS for mass flux stories. I would appreciate any inputs. Sincerely, Sandra
Old   July 18, 2005, 12:01
Default Re: Mass Flux vs Velocity Inlet
Seeker Philip
Hi Sandra,
I am using a similar setup. The correct option to use is the mass flux condition for a well posed solution. You can modify the UDF pretty easily to include the density (assuming no density variation). Phil
Old   July 18, 2005, 12:44
Sandra
Hi Phil, thanks for writing. I'm not sure what did you mean by mass flux condition for a well posed solution. The flow is compressible and I am using the ideal gas option.Did you just mean to multiply my UDF that I had written for the velocity profile by constant density?
Old   July 18, 2005, 14:31
Seeker Philip
Yeah... Thats right for a constant density at the inlet. Make sure you solve the enrgy equation as well if the flow is compressible.
Phil
Old   July 18, 2005, 18:40
Sandra
Thanks. There is still something wrong. I've read a little bit about UDS and mass flux. Is that applicable. Would you know when and why would one use that.
Old   July 20, 2005, 13:09
Seeker Phil
I'm sorry... I'm not sure about that. Do you have any other details that might make it clearer?
Error message: Insufficient Catalogue Size Paresh Jain CFX 32 February 3, 2021 03:37
ChannelOodles Want to prescribe mass flux instead of mean velocity cfdmarkus OpenFOAM Running, Solving & CFD 2 September 22, 2008 12:23
Velocity inlet calculated from Mass Flow Rate Anthony FLUENT 1 January 29, 2007 13:59
problem defining inlet velocity direction salman FLUENT 3 January 3, 2007 11:34
HELP URGENT Mass Flux transient INLET guest7777 Siemens 0 July 20, 2006 05:57
