Home > Forums > FLUENT
Transonic Heat Transfer
Old   July 12, 2005, 18:02
Default Transonic Heat Transfer
Ejaz Ahmed
Hello
I am solving a transonic heat transfer problem in concentric pipe heat exchanger. Hot air entering in the inner pipe are at 500m/s at 1173 Kelvin and their Mach # is 0.7283. Gases are leaving into the atmosphere.
I can apply two boundary conditions at the inlet as fluent manuals guides me. Mass flow inlet or Pressure inlet. But in both Boundary condition i need to specify the Static pressure at the inlet, which i don't have.
Is there any genius who can help me in making the initial guess for static pressure. I am also facing a problem in achieving balance of continuity equation. What could be the REASONS ?
With Regards
Ejaz Ahmed
Old   July 13, 2005, 18:33
Default Re: Transonic Heat Transfer
Robi
For supersonic flow you can consider Mass flow inlet as the boundary condition. But if you consider it then you have to be very careful about static pressure otherwise it always gives some problem in the continuity equation. good luck
Old   July 14, 2005, 04:18
Razvan
"PRESSURE-INLET" boundary condition gives you the posibility to specify both total and static(supersonic/initial gauge) pressure. That means the program calculates the initial velocity field using ecuation:
ptot/pstat=(1+(k-1)/2*M^2)^(k/(k-1))
where k=1.4, M= Mach number.
So if you know the Mach number, then you can easily calculate coresponding static pressure.
Best whishes, Razvan
Old   July 14, 2005, 04:42
Ejaz Ahmed
Dear Razvan
Bundle of thanks for ur responce. I have velocity and static temperature data at inlet. Neither i have static or total pressure at the inlet. Now i cannot apply mass or pressure inlet boundary condition.
Is there any possiblity to solve this problem having the given data.
I am looking to trace the pressure mean while
with regards
Ejaz Ahmed
Old   July 15, 2005, 02:42
Ejaz Ahmed
some how now i am assuming the static pressure on the basis of friction loss in one meter pipe.
thanx for the contributors
Ejaz Ahmed
Thread Tools
Trackbacks are On
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
heat transfer probs by transonic flow Josh_Blue FLUENT 8 March 21, 2010 06:31
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 19:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
