write profile - different length of columns
Old   July 11, 2005, 06:47
Default write profile - different length of columns
Ralf Schmidt
I made a 3D simulation of a flow field and now I want to compare the data in a certain boundary plane with my experiments. Therefore I am using the function write -> profile. I select the plane and the values I want to have (velocity in x,y and z direction as well as vel. mag.) and save as a file.
Now the problem: Fluent writes all the values (x-, y- and z coordinate, vel.-mag., x-,y- and z-vel.) all in one series one after another. When I am trying to resort the values it was obvious, that the x-vel. column is shorter than the others (1119 instead of 1930 values). The others seem to be ok.
Can someone help me?
Ralf
Old   July 18, 2005, 06:40
Default problem solved
Ralf Schmidt
Hi!
I solved the problem: The data were damaged due to the SSH client I used for getting the data from the workstation with Fluent running on to my PC.
The SSH Client transfer mode was "auto-select" and in this mode, some part of the data were cut. Now it is "binary" and it workes fine!
Ralf
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Unsteady Boundary Profile with data file Arianna FLUENT 34 July 29, 2019 16:35
Boundary Profile E61 FLUENT 0 January 5, 2011 08:13
command write profile Stefan Schönwälder FLUENT 0 October 15, 2008 08:27
write profile - journal file mateus FLUENT 1 June 13, 2006 04:26
