July 13, 2005, 03:31 |
Location of interface for sliding mesh
hi I am trying to solve the flow in a stirred tank with rushton turbine. I have got good results with MRF but now i want to solve it with Sliding Mesh. Can i use the same inner and ourter zones of MRF for sliding mesh or i have to change the location of the interfaces.
gopal |
July 14, 2005, 04:30 |
Re: Location of interface for sliding mesh
No, but you have to be sure that the interfaces are surfaces of revolution and defined on practically identical geometries, otherwise you will not get a converged solution. And of course, change "Moving Reference Frame" to "Moving Mesh", but you must know that already.
Best wishes, Razvan |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
Spontaneous failure of moving mesh interface | gareth__it_power | ANSYS | 1 | August 26, 2010 07:50 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 10:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
