How to get good initialization in parameter simulation? |
May 9, 2020, 11:33 |
Alex
Rep Power: 5 |
I have several design points parameter simulation to do.
I do the initialization by the way of 'hybrid+patch', and get the design point0's results successful.But the fluent can't get the design point1's result(floating problem,compute divergence,and so on). So how can I tell the fluent initialize like my way(the ‘hybrid+patch’ way before) before it compute the design point1?use UDF? thanks in advance! |
May 9, 2020, 16:28 |
Parametric Simulation
Better do it outside WB. Standalone Fluent gives provides more flexibility and user control. Within WB, it is controlled by WB. To do automatic parametric simulation in stand-alone Fluent, you can make use of Fluent journal commands.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 9, 2020, 21:17 |
Alex
Rep Power: 5 |
Thank you very much! Best Regards!
initialization, parameter simulation |
Is Solidworks Flow Simulation Good? | corriolisforce | Main CFD Forum | 4 | October 22, 2018 11:44 |
Transient Simulation in CFX | ashtonJ | CFX | 1 | September 28, 2018 01:18 |
finite values inside the simulation domain with hybrid initialization at t =0 | sgbaek | FLUENT | 0 | February 15, 2018 18:45 |
IS Phoenics good for multiphase simulation | zino | Phoenics | 1 | April 30, 2011 19:38 |
Expert parameter to stop the fluid flow simulation | KK | CFX | 1 | February 25, 2008 16:29 |
