Home > Forums > FLUENT
pump integrated into a loop reactor
Old   July 19, 2005, 08:45
Default pump integrated into a loop reactor
Sascha Behrens
i want to do a simulation of a loop reactor which has a gear pump in the circuit. Actually i donīt want to draw a real gear pump but just want to have an element in the circuit that adds a pressure / momentum to the flow. I tried with pressure inlet, velocity inlet ... but always fluent doesnīt allow to have inlets with two adjacent cell zones. So how can i get something that gives a pressure or momentum into a loop?
thanks
sascha
Old   July 19, 2005, 14:05
Default Re: pump integrated into a loop reactor
Jason
I'm not sure if this is the best choice (anyone out there with a better suggestion, feel free to correct me), but the only thing that comes to mind is the fan BC.
You'll need to figure out a way of defining the pressure rise across the fan as a function of the velocity through the fan. There's plenty of options though, so you should be able to find one that fits your system. Chapter 7.20 in the manual has some good info, and an example on defining the deltaP vs V.
Hope this helps, and good luck, Jason
Thread Tools
Trackbacks are On
Problem with Gmsh nishant_hull Open Source Meshers: Gmsh, Netgen, CGNS, ... 23 August 5, 2015 02:09
my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 02:30
Regenerative pump modelled in FLOEFD pro YYY FloEFD, FloWorks & FloTHERM 2 October 5, 2009 05:04
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
Discharge pump flow Ali Main CFD Forum 0 March 5, 2003 18:11
