Home > Forums > FLUENT
UDF to rotate
Old   July 20, 2005, 07:48
Default UDF to rotate
Jon
Hi all,
I'm looking to write a udf to produce a rotating motion (rad/sec) for a volume, around a specified axis (0,0). I've been able to produce udf's that produce a circular motion by specifying a sinusoidal x and y motion, but now need the volume to actually rotate.
Hope you can help,
Thanks,
Old   July 20, 2005, 08:08
Default Re: UDF to rotate
edi ghirardi
The following is an example on how to ramp up the rotational speed as function of iteration supposing that you use MRF (or SRF). Changing it as function of flow time for unsteady simulations should be straightforward (Rp_Get_Real("Flow Time")).
Hope this helps
Edi.
#include "udf.h"
#define Niter 25 /* iteration update interval */ #define omg_mn 0.00001 /* starting omega */ #define omg_mx 20.0 /* final omega */ #define del_omg 0.2 /* incremental omega */
DEFINE_ADJUST(myadjust,domain) { int zoneID; int iter = (nres==0)?(1)(int)count2[nres-1]); float omega; Thread *tc;
zoneID = 2; tc = Lookup_Thread(domain,zoneID);
if ( (iter%Niter)==0 ) { omega = omg_mn + (iter/Niter)*del_omg; if ( omega > omg_mx ) omega = omg_mx; THREAD_VAR(tc).fluid.omega = omega; Message("At iter=%d - update omega to %f\n",iter,omega); } }
Old   July 20, 2005, 08:22
Jon
thanks for your reply Edi. The rotational velocity is constant throughout however (150 radians per second). I just want to make a volume rotate about a central axis at this speed. Ideally, the udf would use t and simply increment the angle of rotation based on the value of t during interation.
Thanks again,
Old   July 20, 2005, 08:42
edi ghirardi
Sorry, might be a silly question, maybe I misunderstood your problem again, but what about defining a moving wall? In the BC panel you can define the rotational speed (relative to adjacent cell zone) and axis of rotation.
Edi.
Thread Tools
Trackbacks are On
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
How to rotate a wall?( with udf) pejmanpark Fluent UDF and Scheme Programming 0 July 13, 2009 07:37
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
