Home > Forums > FLUENT
timesteps reqd for the convergence of unsteady flo
Old   July 27, 2005, 11:42
Default timesteps reqd for the convergence of unsteady flo
satyam
hi im simulating the flow past a barge(a displacment vessel) using vof,realizable k-epsilon,unsteady model.iam using maximum iterations per time step as 20 and the time step size as 0.001.can any one suggest me for how many time steps are reqd to acheive the convergence. thanks in advance
Old   July 28, 2005, 07:33
Default Re: timesteps reqd for the convergence of unsteady
Swarup
This is completely problem dependent for any model. Swarup.
Old   July 28, 2005, 07:39
satyam
how can i calculate the min time required
Old   July 28, 2005, 07:51
dirk
What do you think should the converged solution in your unsteady simulation be ? What do you want to compute ?
Old   July 28, 2005, 07:56
satyam
i want to compute the total force,convergence of the coefficient of drag
Old   July 28, 2005, 09:30
dirk
Then you simply have to monitor the development of drag and hope that it reaches a steady state or oscillates around a steady mean value.
Dirk
Old   July 28, 2005, 09:37
Swarup
then you should run simulation until Cd tapers off. do you have a target for total flow time? if so, then you should see that before your flow time is over, you have achieved convergence. further, if you are assuming incompressibility, then you should try to obtain convergence as early as possible. you have time step size deltat and number of iterations per time step to choose from. one more issue is whether your problem is inherently unsteady and has no steady state solution (like free convection)or you are finally interested in obtaining a steady state solution. Swarup
Thread Tools
Trackbacks are On
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
convergence for an Unsteady simulation Palani Velladurai FLUENT 1 March 19, 2007 11:56
Unsteady simulation convergence Tomislav Main CFD Forum 1 December 6, 2006 08:53
General Unsteady solution convergence Freeman Main CFD Forum 0 December 7, 2005 18:08
