-   -   Simulating a solid spinning disk in IcePak (http://www.cfd-online.com/Forums/fluent/37412-simulating-solid-spinning-disk-icepak.html)
Akash July 28, 2005 18:39
Could anybody guide me as to how I could implement a rotating disk in IcePak?
Thanks, Akash
manohar July 29, 2005 12:13
Re: Simulating a solid spinning disk in IcePak
hi akash,
can u explain us little more clearly. i mean, do u need the solid domain inside? normally what the CFD people will do if there no analysis is going to do on the solid is "places a void in place of the solid". and regarding rotation, just simply give the walls as the rotating walls.
Akash July 30, 2005 16:07
Hello Manohar,
Thanks for your response. I have an enclosure with some heat sources and a spindle motor on which a disk is mounted. The disc spins with a certain angular velocity. As the spinning disk will move the air around it and hence cause a difference in the heat transfer effectiveness, I would need to simulate a spinning disc inside the enclosure too. In IcePak, can I just create a wall,calculate the linear velocity from the angular velocity and then specify that value as components in the X, Y and Z directions? Any suggestions will be really appreciated.
Regards, Akash
manohar July 31, 2005 02:00
hi akash,
i think for ur case if the disk is fully solid (means, there is no holes or vanes in the disk) u can just define the wall as rotating. that is sufficient. i dont know exactly but as of my knowledge we can't rotate the solid domain (almost i tried for one month but i didn't get for my case). for anything else i am ready to help u.
Akash August 1, 2005 11:21
I got in touch with IcePak tehc support. They say that the new version of IcePak--4.2 has the capability to support a spinning disc.Thanks so much for all your assistance Manohar.
Regards, Akash
