October 20, 2017, 23:18 |
Learning c++ for fluent
Have a nice time!
Rep Power: 11 |
Hello, I want to learn c++ programming language to use it for Fluent, I need any help as a beginner, I want to learn how to write simple codes, generate a mesh and solve it...
Thanks |
October 21, 2017, 07:48 |
Marcin
Rep Power: 9 |
Hey,
As far I know, If you want to use UDF's you need to learn the C programming language - not C++. |
October 21, 2017, 11:11 |
Have a nice time!
Rep Power: 11 |
Thank you very much sir, I have visual studio software, so, I think I can start learning Also, I have written a simple code using c++ language and integrated it to Fluent and it worked
Thank you again! |
October 22, 2017, 11:59 |
Marcin
Rep Power: 9 |
Maybe C++ will work too - I read in UDF Manual that the programming language is C here. Maybe it depend on your compiler/computer/system/etc.
For learning UDF's I recommend starting with UDF manual. I think that in many situations you won't need a special skill in programming, there are some typical UDFs from ANSYS that will let you set a typical thing like velocity profile. However, I don't have a wide experience here, and I'm learning C, I started with a book with examplary codes. Regards |
October 22, 2017, 21:23 |
Alexander
Rep Power: 34 |
ANSYS Fluent Customization Manual + google
Best regards |
October 22, 2017, 22:39 |
Have a nice time!
Rep Power: 11 |
Thank you all!
machine learning algorithms | Rajesh Sundaram hsejarm | Main CFD Forum | 4 | February 26, 2021 02:16 |
Learning OpenFOAM-new user | anand_30 | OpenFOAM | 3 | June 18, 2016 11:08 |
openfoam learning | sinatahmooresi | OpenFOAM Pre-Processing | 2 | December 13, 2015 13:41 |
Fluent learning modules - Cornell | Reza2012 | FLUENT | 2 | May 28, 2012 10:17 |
Anyone has PETSc learning experience? | bearcat | Main CFD Forum | 3 | March 25, 2010 20:33 |
