time step size
Old   July 31, 2005, 06:39
Default time step size
Sham
Does anyone know how to calculate a time step size? I am modelling a cylinder in water. I use a time step size of 0.005 and the solution takes more than 48 hours to iterate. Is this normal?
Thanks.
Sham.
Old   July 31, 2005, 07:12
Default Re: time step size
Swarup
Calculate characteristic time scales of processes (momentum, mass and heat transfer and reaction rate)involved in your problem. you should use a time step smaller that the smallest characteristic time you have. this method properly resolves the fatsest and slowest of the processes. however, if you are only interested in obtaining a steady state solution and are not bothered about temporal accuracy of solution, then you should take advantage of unconditional stability of implicit method and use larger time step. also, if you are not encountering high velocities, then using segregated solver will definitely improve speed of computation. another thing you may look at is whether your mesh is very fine. Hope some of these things will help in reducing time of computation.
Best of Luck,
Swarup.
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
natural convection - time step size co2 FLUENT 7 June 3, 2004 21:56
how to increase time step size? co2 FLUENT 6 May 17, 2004 07:25
