August 1, 2005, 03:57 |
3D - Grids - Gambit
When I want to create a 3-dimensional grid, it's necessary to create a 1-dimensional(line) grid at first and a 2-dimensional grid at second before connectiong this points to create a 3D-Grid inside the body.
Thanks! Gernot |
August 1, 2005, 04:18 |
Re: 3D - Grids - Gambit
Hi!
I'm not sure if I understood your posting correctly, but you may also create directly a 3D object in gambit (e.g. cube, sphere, etc.) rather than to draw first some lines, connect these to faces and create of the result a volume. In the same way, meshing a 3D object can be done bottom-up (I guess like you described it: first edges, then faces, and finally the volume), or top-down, i.e. by a direct meshing command. Generally, by bottom-up, you have much more influence on how the mesh will look like afterwards. The price for this flexibility is the time that you need to spent to create a nice 3D mesh by hand. Hope this helps a bit! Philipp |
August 1, 2005, 13:22 |
yea it helps!
Thank you very much! Gernot |
August 4, 2005, 03:31 |
thanks actually i want to solve a problem like sheet which passing in a cube which is full with water and sheet is hot around 1000k and water get heat from that sheet and sheet is moving at a velocity of 5m/s so i want to know if there is giving any moving mesh to sheet wall means both side of wall of sheet if any more help give to me about solving this problem please send
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
making C type grids in gambit | Usman | FLUENT | 3 | September 20, 2008 09:31 |
How to make C,H, and O type grids in Gambit | Muhammad Usman Qureshi | FLUENT | 0 | August 23, 2007 06:37 |
Gambit problem: unstructured grids | Alonso Zamora | FLUENT | 3 | June 14, 2004 17:40 |
Plot3d grids > Gambit > Fluent 5 | David C | FLUENT | 1 | February 16, 2001 16:29 |
