August 15, 2005, 20:12 |
turbulence specification at inlet
Does anybody have an idea how sensitive the turbulence models in Fluent are to the turbulence values at the inlet? Is it just used as a boundary condition to initialise the solution? I am currently validating an experiment about sails where the oncoming flow has a fine scale turbulence. I am using k-w sst. Cheers, Ziya |
August 16, 2005, 01:24 |
Re: turbulence specification at inlet
As all turbulence models based on k-e model, sst-kw is not very sensitive to inlet values. However, pay attention that Fluent is using user inlet values for turbulence quantities (whichever way you decide to specify them) into calculations!!
In your particular case, I think is better to use a combination of turbulence intensity + turb. lenght scale or turb. viscosity ratio. Best wishes, Razvan |
Turbulence length scale and integral length scale | rizhang | CFX | 2 | April 22, 2016 07:22 |
Default inlet turbulence for LES | N Barton | CFX | 11 | July 24, 2015 00:34 |
Species mass flow inlet | lorenz | FLUENT | 3 | March 15, 2012 07:26 |
Mass Flow Inlet with Velocity specification | bernarde | STAR-CCM+ | 1 | December 3, 2009 23:13 |
Inlet : Turbulence Specification Method | PK | FLUENT | 0 | February 2, 2006 10:40 |
